Can only get 4500 RPM
RE: Can only get 4500 RPM
My Bronco is EEC-IV, and it goes past 4250, it will go as high as it wants until valve float...
ORIGINAL: fats429
For what this is worth the trucks and big SUV that use EEC-4 have a rev limmiter at 4250
ummm..why would you want to free rev your motor to red line? Your likely to do damage to it. Not sure about your year car but 99+ all have revlimiters. If you're not in gear (moving) and you just stomp on the gas in neutral (or with the clutch pushed in), the computer will bounce you around 4-4 1/4K. When you hit that RPM, it starts cutting the fuel to the cylinders. Under a load, the cutoff is around 6250. Unless you've changed some internals on your engine or it's a weekend race only car, why worry about it on a daily driver?
You're only inviting valve float...
Omgitsa88Stang
10-05-2015 07:33 AM
