couple questions
couple questions
on my 84 gt what rear end do i have considering it stock?
and also since my 84 mustang has single exhaust(hate it) can i put 87-93 headers and exhaust on there if i took them off of one?
and one more ? when i bought the car it had the stock tow hitch on theretrying to get it off is there any trick to do it.
RE: couple questions
I think '84s have the 7.5 rear end. I know my '85 does. And I'm pretty sure the headers and h-pipe and dual exhaust will fit your car too. The only problem is that '85 and older models have a single hump tranny crossmember. So you'll need a tranny crossmember out of an '87 and newer model. And by hump... I mean... it only has a raised section for the exhaust to go under on the passengers side. The newer ones have a "hump" on both sides for the exhaust. Here's a picture of an 8.8 rear end. Look under your car and count how many bolts there are on the cover...... If it's the same as the picture. Than you already had an 8.8 swapped in.
[IMG]local://upfiles/71653/14C2270F897A4E5AA2A755109433E670.jpg[/IMG]
I'm pretty sure the 7.5in and the 8.8in look similar so counting bolts isnt a good ID
try to get the exhaust for a 1986 GT, plus the dual hump tranny member from a junkyard or ebay
I just looked... they have the same amount of boltd. But the pumkins look totally different.Here's a picture of the pumpkin on a 7.5 if it helps any.
[IMG]local://upfiles/71653/3BB199BB9398457F96AB13F956C7F50C.jpg[/IMG]
