Clutch Advice needed
RE: Advice needed
ORIGINAL: PRO50SC
Have you manually adjusted the quadrant after replacing the cable? You should have 1-2 inches of play
Manually Adjust the stock quadrant? I didnt know it was adjustable. Should I attempt to adjust it or just get a new one? Is it difficult to replace?
RE: Advice needed
ORIGINAL: PRO50SC
Ahhhh, you bought an adjustable cable. So are you adjusting it the correct direction? How much toe play is there and do you still have the factory quadrant set up?
So what's the best way to adjust this cable? Should I have someone press it, and then adjust accordingly?
Jskeezy84
09-08-2015 01:40 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
