Getting harder to start...... Help
Old 07-01-2008, 09:10 PM
95Saleen
95Saleen's Avatar
Default Getting harder to start...... Help
I just got my 95 GT a week and a half ago. It has been getting more difficult to start when cold. The thing cranks for about 5 to 10 seconds before it fires. Then when it does fire it idles ruff for a little while. Eventually it runs itself back to what i consider normal. I just replaced the fuel filter. I also put asome injector cleaner it as well. Oh I also replaced the TCS only because it was in my trouble shooting list of things to look into from the Chilton manual. Anybody have some good suggestions. Thanks for the help.
95Saleen is offline
Old 07-01-2008, 10:27 PM
redpony88
redpony88's Avatar
Default RE: Getting harder to start...... Help
check the battery, if the battery is old it may not be putting out enough to spin the starter fast enough, also could be the starter
redpony88 is offline
Old 07-01-2008, 10:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I'd perform a fuel pressure test and check for leak down..could have injectors leaking down or a bad check valve in the fuel pump
mjr46 is offline
Old 07-01-2008, 10:41 PM
93 LX FiveO
93 LX FiveO's Avatar
did you put the filter in the correct way?
check the ez things first
93 LX FiveO is offline
Old 07-02-2008, 10:23 AM
95Saleen
95Saleen's Avatar
Thank you guys for the info. As far as the battery its brand new. I don't think its the starter. It feels fuel related. The fuel pump is new or so I was told. I don't know why he didn't change the filter when the previos owneer changed the pump. I am going to look into the pressure of the fuel next. Thanks mjr46. I know for a fact that the filter is going in the correct way I checked then double checked. by the way sweet picture 93LX fiveO. you will have to share the secret how you did that.
Thanks for the help guys...this Forum has been great.
95Saleen is offline
Chandler555
09-24-2015 06:48 AM
MustangJourney
09-02-2015 04:32 PM
chain
08-17-2015 08:52 AM
Lawerence
04-11-2005 02:09 AM
GrayGhost01GT
08-05-2004 07:15 PM
Quick Reply: Getting harder to start...... Help
