Issues After Head and Intake install
Old 08-08-2008, 04:03 PM
Alero99
Alero99's Avatar
Default RE: Issues After Head and Intake install
the new intake, is much larger then stock, so the steock pcv hose will not reach...
as i said i have tried plugged the holes and there is still air being sucked in somewhere...
Alero99 is offline
Old 08-14-2008, 10:46 AM
Night Terror
Night Terror's Avatar
Hey Guys its me Alero99
car has sat now for the past 4 weeks, and it ran all of 10 minutes in that 4 weeks...
I found some interesting things a few days ago...
I took off the upper plenum to check the length of my pushrods
and what do i find when i get the valve covers off?
Coolant in the oil!
now this is the second time i have taken the motor apart, both times the damn bolts on the lower intake although i ahd them torqued to spec they would be loose when removing the lower intake...
now i am looking at new lower intake bolts maybe hte ones i have, have seen better days... also i am looking at taking off the timing cover to ameks ure my timing marks on the chain and gears are lined up.
Night Terror is offline
Old 08-14-2008, 11:49 AM
red95gtconvert
red95gtconvert's Avatar
Did you use thread sealant on the lower head bolts?
red95gtconvert is offline
Old 08-14-2008, 01:46 PM
Night Terror
Nope... but i have put hte heads on before with out hte sealent on the bolts
but it doesn't matter now my baby is going to a very good local shop to be taken care of
Old 08-14-2008, 02:46 PM
AdderMk2
Banned
AdderMk2's Avatar
you should have done that in the first place... it really does hurt to see someone with such little mechanical knowledge, to attempt a job like this...
then have absolutely no clue how he screwed it up.
did you torque the heads properly? did you use sealant around the coolant passages in the heads where the intake bolts up? do you have any clue wtf you are even doing?
AdderMk2 is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
Redneck1465
08-08-2015 10:39 PM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: Issues After Head and Intake install
