Future stang owner needs some info
At the end of this summer im goin to be look for a 94-95 Mustang GT 5.0 5spd. maybe a convert., not sure yet. Is there any problems i should look for on these years and is there anything diffenert between the 2?
RE: Future stang owner needs some info
there isn't much difference between the two. it will be sort of slow though. those were heavy especially the convertible. i have also heard that the computer from those years wasn't that great once you started adding mods. (stuff like intakes, and cams)
on the positve side, it is a 5.0 and they are really strong and can last many miles if properly maintained. also parts for them are cheap and these motors can be made to run very fast for cheap. the best mod to do first would probably be rear end gears. 3.73-4.10 depending on how much highway driving you do.
good luck in your search.
The coupes arent really that much heavier. But like Fordguy17 said, the Verts are fatties! I had one! A poweradder could take your mind off of that really quick though .
I see so the convert. are alot heavier then the others. I can see why with reinforcin everything. I wont be doin alot of highway use cuz im just a poor country boy and i dont very many places. I'm defenetly planin on takin very good care of it and addin some HP to it and maybe race it a few times. What is the MPG usally on a stock setup?
I'll do headers and full exhaust and probably gears and a lowerin it just alittle and some big rims and better tires for a starter then a turbo later on next summer. Whats the MPG on a stock set up no one answerd that?
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
