would a longer one affect whether or not the car drives straight while letting go of the wheel. I replaced everything except I put the un even ball joints in, not realizing the difference. The only thing I think might be worn out is the rack and pinion, could that affect straight line driving?
first put in the right ball joints
then instead of getting a stock rack again, get a good one with a new pump. i have a agr rack and pump in my 83 with the 15:1 ratio the steering is so smooth
Pull could be a tire also,try switching the two front tires and see if the pull changes if so then you found the problem..Also did they tell you if the caster was good when you got the alignment?And a sn-95 ball joint is shorter then the fox because of the thinner spindles so i really don't know how you installed two different ball joints.
You mean one is longer than the other, both being the new ones you got, or you mean the new ones are longer than the old ones? I know that my X2s were a little longer than the stockers..
