vibration problems
Old 12-01-2008, 05:09 PM
  #21
nseoi
nseoi's Avatar
tie rods? check play in the rak n pinion. umm... warped disc brakes? did you get NEW tires or just different tires? properly balanced? warped wheel(s)? has the car been wrecked before? take it to a chasis shop
all guesses
nseoi is offline
Old 12-02-2008, 07:56 PM
  #22
lmatt
lmatt's Avatar
Switched wheels with another fox body that doesnt have vibration issues. Vibrates without any wheels on the car. It vibrates sitting on jack stands. It doesnt have to even be moving down the road to vibrate. And never been wrecked. Still has the vin stickers on the fenders and hatch.
lmatt is offline
Old 12-02-2008, 08:49 PM
  #23
Portmaster
Portmaster's Avatar
Check pinion flange with dial indicator. Check trans oil level. If you get some on your finger look for metallic shavings, check pinion play.
Portmaster is offline
Old 12-03-2008, 11:45 AM
  #24
lmatt
lmatt's Avatar
Transmission has been gone thru, new bearings all thru. Checked the flange with a dial indicator, no problem found. Thanks.
lmatt is offline
Old 12-03-2008, 12:57 PM
  #25
mustangsneverdie
mustangsneverdie's Avatar
have you checked to make sure all your tires are in balance
mustangsneverdie is offline
Old 12-03-2008, 03:46 PM
  #26
Portmaster
Portmaster's Avatar
Get a transmission yoke from an old driveshaft and remove your driveshaft annd put the yoke in. (make sure the rear of the trans is a little higher than the front) and run it up to speed on the jackstands. If it shakes you will know it's not in the rear. You could slide the transmission out after that and see if it still shakes (manual only) If it still shakes you may want to look at your flywheel and balancer combo. It's just a process of elimination now.
mtgldr
02-03-2024 09:00 PM
Omgitsa88Stang
10-05-2015 07:33 AM
mdj89
09-23-2015 08:49 AM
ccdguy
09-19-2015 05:20 PM
LivingInThePast
09-16-2015 12:20 PM
Quick Reply: vibration problems
