Running too rich, Not a good Dyno result
#22
first off your a/f ratio was perfectly fine. when you are running at wot you will run rich to protect the engine from blowing itself up. your hp and tq numbers are normal for what you have done which is absolutely nothing but throw a cam in a stock engine which does you no good at all.
a little advice for you ditch the cam heads and intake for something better if you want to make more power.
#23
Sounds good
So C/H/I. I will start looking into that. My goal for my car right now is to get into the mid 12's at the track...so basically I am looking to drop 2 seconds off my time. Will H/C/I get me there or am I going to need further upgrading? I am not interested in NOS or anything like that! Thanks
#25
Is there a good street tire for the track or should I go with a street slick? Are you talking about sub frame connectors, the weld in type, and what else suspension wise. And one more thing, do I need my computer 're-flashed'? I'm not sure exactly what that is, but I have talked to a couple of guys that mentioned it!
#27
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
