removing intake silencer?
a few people i have talked to have said that a cheap way to gain more power is to remove the intake silencer. The only problem is, i dont know how to or where it is on the intake. So does anyone know how to remover it an where it is? Thanks
RE: removing intake silencer?
Alright, take off the airbox lid and remove your filter. You should now see a hole in your fender wall, with a plastic peice on the other side. There are I think 4 bolts on the wall that hold it on. Remove those 4 or so bolts and it should come off. Once the air silencer is loose you will need to remove it through the bottom of your car.
