iacv
Old Mar 14, 2009 | 02:43 AM
lx5.0's Avatar
lx5.0
Default iacv
will anything happen if i flip around the iacv
Old Mar 14, 2009 | 12:04 PM
lx5.0's Avatar
lx5.0
so does anybody know if anything will happen will car idle the same have to flip it around because it does not fit because anderson cai is in the way
Old Mar 14, 2009 | 06:27 PM
Compression's Avatar
Compression
As long as both of the ports still line up correctly it shouldn't matter which way it faces.
Old Mar 14, 2009 | 08:33 PM
sprinklerdr's Avatar
sprinklerdr
If you flip the IAC valve, there's a good chance that your idle will shoot thru the roof. I had that problem on my Thunderbird TC when I replaced it. Being a master mechanic (that's sarcasm), I just put it on without reading the directions. After removing it about 6 times I found the slip of paper that said in big letters "Install in the opposite direction as OEM". Damn........So in short: It will mess your idle up since there will be no plunger to re-direct the air as needed and your idle will run upwards of 3k.
stangsnort
Mar 24, 2015 11:34 AM
antnvlz1294
Feb 17, 2014 12:17 PM
olddadwitsend
Sep 30, 2013 03:50 PM
Moonshine
Jul 2, 2011 08:43 AM
ShuggaShane05
Feb 16, 2011 10:01 PM
