KOER test, codes, and i couldnt get KOEO to work? help.. ( lean car )
#21
have you ever pulled the upper intake off? consider doing this to check all the vacuum lines under there as there hard to get to with it on. if its ghost white spark plugs id think vacuum leak. or fuel pressure.
#23
Never questioned that, whats an easy way to check?
That's actually impossible, it runs like a beast when its not ideling. but then agian, white spark plugs....
circles. haha
how can i check the fuel pressure?
#29
you can not rule out fuel pressure! obviously its not running right because its very lean. autozone/checker has a fuel pressure gauge that has a long enough hose to bring in through the window with you. so you can drive and watch it. you have to deposit 30 bucks but you get it back.
#30
im going to be happy and also pissed if its something as easy as a fuel filter..
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
