Mustang Timing Question
Old May 27, 2009 | 05:26 PM
wrenchturner75's Avatar
wrenchturner75
just listen carefully for detonation when lugging it. you dont want to rattle a motor its very destructive. if its pinging back off a degree or 2 or try a better grade of gas.
Old May 27, 2009 | 06:38 PM
NotchAbove's Avatar
NotchAbove
Good point @ 14* I would run 93-92 only. (I run 93 no matter what anyway).
Old May 27, 2009 | 07:29 PM
sgreiner5.0's Avatar
sgreiner5.0
Yes, I run 93 all the time anyway.
Well, the clutch cable went bad again. It was probably due to the heat before I fixed the timing. I decided to take it off and inspect it and sure enough, its binding up. Im going to get another one, and when I install it and test drive it, I will keep you guys updated. I am also going to get some of that heat wrap to put around the clutch and speedo cables.
Old May 31, 2009 | 01:17 AM
sgreiner5.0
Ok, Well I got to test drive it. I wrapped the new clutch cable in some heat wrap along with the speedo cable. Also, after I set the timing correctly, the heat under the hood isnt as bad anymore. The clutch feels so nice now. So I guess that was the problem, the timing. Although throughout this whole fiasco, I did find the t-stat bad as well. This was a blessing in diguise as my temp sending unit went bad earlier.
Thanks guys for all your help. I dont think I would have ever came up with that idea of the timing being off. Im glad you did.
Thanks Again,
SG
Diode Dynamics
28
May 26, 2022 12:02 PM
ding56
Aug 14, 2015 02:40 AM
StangMuscle
Aug 12, 2015 07:27 AM
$A_Money$81
Aug 11, 2015 01:30 PM
daytooday
Aug 11, 2015 09:22 AM
