water pump rotation.
Was there a year with a standard rotation water pump in the 5.0 with a serp belt.I dropped a 5.0 in my 65 mustang and i was trying to use what i have or the cheapest way to set this up.It is 91 motor backed with a T5 trans.Any body have ways i can set this up i would appreciate it.
You use a standard rotation water pump and then get a pulley set that has a standard rotation 6 groove serp setup. That's how I'm running mine. That way the radiator openings are on the correct side.
Why do u need to change rotation. I'm currently running only alternator and water pump and crank, using a 41 inch serp belt. I did have to get rid of the automatic tensioner and use a new alternator bracket from march pullies, which incorporates a manual tensioner.
jwog666
12-27-2021 08:09 PM
