Transmission Cross member question
I put in a new cross member and the stock bolts seem much smaller the the bolt hole in the bushing the stock ones are 3/8" and the hole through the bushing can take a 1/2" bolt.
The problem is a 1/2" bolt does not fit through the holes in the chassis. Does anyone know if it would cause problems if i drilled the holes out to 1/2"?
