Alternator Pulley Disintegrated?
Old 07-27-2009, 03:24 PM
mgmuscari
mgmuscari's Avatar
Thumbs up
Originally Posted by Tony71502
The starter solenoid is on the driver's side fender on my car, right near the ignition coil. The cable only needs to be so long as to run it from the solenoid to the radiator support, underneath the air intake, then to the back of the alternator. I used a cutoff wheel and notched the alternator bracket in a whole 1-2 minutes. Even left the bracket in the car and just covered the motor or other important part with a towel to block out metal shavings.
So I should just be able to follow the existing wire over to find it - good to know. Hopefully I won't have to notch the bracket... I do have a dremel but the car is currently too far from an electrical outlet to use it. The alternator that's currently on there seems pretty big to begin with so maybe it's already been done...
Thanks for the advice!
mgmuscari is offline
Old 07-27-2009, 08:52 PM
Tony71502
Tony71502's Avatar
The stock alternator power wire is in the main harness running along the radiator core support, I think. If you go 3g you have to modify the bracket. 2g you don't.
Tony71502 is offline
Old 07-30-2009, 12:29 PM
mgmuscari
mgmuscari's Avatar
Smile
So I just got back from a 1.5 hour test drive... the new alternator I put in is working great, and I'm well-satisfied with the one-wire system. The internal regulator keeps the voltage rock-steady at 14.4v no matter what accessories I try. I notice a tiny drop when the windows are all the way down and won't go any further... that seems normal, though.
The Summit Racing 100-amp 1-wire alternator I got switches on around 800rpm so the battery does charge at idle. To hook it up I elected to install some 2/0 wire from Home Depot - it cost $17 and can definitely handle a lot more than 100 amps of current. I put in a 175 amp fuse link and fastened it down to the positive terminal on the starter solenoid - right where the hot battery cable is attached. I took special care to make sure it wouldn't twist around and short down to the negative terminal. All the old alternator connectors are now taped off. A few of the things I had to do weren't clear to me at first, such as how to lift the belt tensioner and which terminal on the starter solenoid to hook the new charge cable to. The 2 10AWG black/orange wires that come from the stock setup end up going through a green 14AWG fuse link into the solenoid. It meets up with the positive battery cable there.
If anyone wants pictures, PM me.
Old 07-30-2009, 12:32 PM
Tony71502
Tony71502's Avatar
Good to hear it worked out well.
Old 07-31-2009, 10:19 PM
Jfsram
Jfsram's Avatar
What happens sometimes is the nut that holds the pulley onto the shaft. It's not torqued down properly and it loosens itself off. Now the pulley is spinning the shaft but it wobbles around a bit. Well, a bit, turns into alot and eventually the pulley is toast.
Jfsram is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
spdeplayer2
10-24-2015 09:45 AM
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator Pulley Disintegrated?
