Help Figuring Out where this vacuum line goes
This should help you understand what everyone is saying.
1st attachment.......... nipple sticking out that says Charcoal Cannister.
2nd attachment......... shows you how it's routed .
ok thanks that cleared it up i didnt see that charcoal canister plug on the intake i only saw the bigger hose in there so i will check it out, but its back at shop that replaced distributor because ignition module is suspected to be bad again
FWIW that line is not only disconnected and capped off at the intake on my car, but it's also been burned up by laying on the headers at some point. I got the car with no smog equipment on it. My car runs fine without it, speed density setup. Even passes NJ emissions with no problems, heh.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
