T5 to C4 neutral safety issue
I am swapping to a C4 in my 87. My shifter has a built in neutral safety switch.
Where do I connect it? I looked in my Haynes manual at the wiring diagrams but didnt see a neutral safety connection. Im not sure if T5 cars have it or not but I assumed Ford used the same harness on both.
Any ideas?
Any ideas?
What I did was on your starter relay at the top there is a little wire,if you pull that off,the starter won't engage. So I spliced my switch into that wire and I still have my clutch pedal in the car tucked under the carpet so you have to rest your foot on that and then your switch on the shifter has to be made. Get me?
lincolnshibuya
12-08-2015 04:37 PM
