Sweating the small stuff
Old Jan 18, 2011 | 11:41 PM
Dj_Seph's Avatar
Dj_Seph
Oh. The miss is gone. Seafoamed the car and it went away.
Old Jan 28, 2011 | 01:30 AM
stangfreak09's Avatar
stangfreak09
it may b a small vac leak listen for hissing on top of ur motor those vac lines rot and crack pretty easy if not that def timing
Old Jan 29, 2011 | 09:01 PM
g2_5point0's Avatar
g2_5point0
as for the vibration in 5th, i've had an issue too. my only suggestion is to check the harmonic balancer for wobble, u-joints and even transmission mounts to see if those are fine. any and all could cause terrible shaking/vibration while driving at a certain RPM.
Old Feb 1, 2011 | 10:08 AM
Dj_Seph's Avatar
Dj_Seph
Had timing professionalaly done. It's fine. Also changed all vac lines with new. Still vibrates like hell. Harmonic balancer is new along with the transmisssion mount. On the original 87 universal joints though. See if changing those fixes it.
Old Feb 1, 2011 | 10:56 AM
frdmstng1986GT's Avatar
frdmstng1986GT
Can't hurt to change the u-joints but if its u-joints causing the vibration it would be more relative to driveshaft rpm And vehicle speed, not gear relative. The fact that adjusting the timing back changed the rpm that the vibration occurred leads me to believe its more of an internal engine or trans issue. Just my $.02
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
daltron
Apr 28, 2016 08:10 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
UrS4
Sep 30, 2015 10:13 AM
