My 95 is running way lean help please
to the OP, my car was mostly stock, i installed an adj. FPR with a 190lph, (car had a full exhaust, CAI, and some 1.7s with upgrade springs) and i needed to jack my pressure up to ~45-46 for it to burn 12.9:1 at WOT so try bumping up the pressure a bit if the other tricks dont work...
Ok fixed it. After the plug change, yesterday I cleaned the MAF and she ran a liottle better, so I changed my thurmostat back to a 195 and little better, but still way lean, so I change the ETC and wala all my poer and more came back with no more lean condition. I can pull hard in 5th and 4th on the free way and she reads at about 12.5 to 13 AFR.
Thanks every one for the help. A Stiky sould probly be made for a lean condition since their is one for a rich condition.
Drive your stang hard every day thats the way they like it.
AdderMK2 I will research this and if your right I will go back to copper core, however I never disagreed with you in the first place, and did think about what you said. On the other hand NEVER reply on my post ever again. I don't need help from someone that can’t be descent to others on their post YOUR ATTITUDE is uncalled for, so grow up.
he is man he poasted on one of my things asking questen said i could not tune my own car well i reserched and its runing quite fine megasqurtII trollin on me told me i got an ebay turbo when never got it from ebay its a garrett 75trim turbocharger with a 110 a/r on it from a 7.3 powerstroke and the replacement turbo is close to a grand i need to still git my 44mm v clamp tial wastegate and bov and im done i didnt use a aem fic tho he was trollin on me about its a computer came with stock tune and i did some adjustmints on it i have a fule stand alone ems and he dont know how to talk to peopple i was scroleing through lookin at stuff on here being bored and yet again i find him harasing numerouse peopple with his addatude...........i would also check ur injecktors see if they are gunked up not flowing properly can make u run lean and check all vackume leacks includeing egr i would personaly deleat the egr less things less problems mine runs fantastic w/o it i cant see it know but also pull ur injeckrots also work on timeing pre det may be a problem
I troll hard... But I dont bump threads from over a year ago.
Good Job!
true true sorry...
