E-Brake Tightening
RE: E-Brake Tightening
look at the back for the drum and you will see a small strip of rubber. behind the piece of rubber is the star wheel to adjust the e-brake. take that piece of rubber out and put a screw driver in there. use the screw driver to turn the star wheel and adjust the ebrake.
I adjusted my drums and the ebrake is still loose. There is an equalizer right behind the crossover of the stock h pipe. I believe the equilizer bolt is under the center console and tightening it with the rear wheels lifted will adjust it to a tighter tension.
ccdguy
09-19-2015 05:20 PM
cardsrus1
19
09-15-2015 08:37 AM
