GAUGE QUESTIONS
GAUGE QUESTIONS
ok i have a 86 stock with cold air intake and 3.73 gears. my dad has a mechanical temp gauge and an oil pressure gauge. i know how to hook up the water gauge but can you guys help me out on how to hook up the oil pressure gauge. thanks guys
1st, your mods have nothing to do with an oil pressure gauge.
2nd, you need more than just the gauge. You will need fittings to space your oil pressure sending unit off of the block, and tie the hose that will run to the gauge, into it... preferably via a T-fitting
i know i dont need the oil pressure gauge but its coming with the gauge and i just wanna know what it is because the stock gauges arnt that accurate and i just want to know what the pressure is
I told you all you need to get going in the right direction. The rest of up to you.
I Can't hold your hand forever, you eventually need to learn to walk on your own.
