Starting issues need help
Old May 18, 2011 | 11:12 PM
khodson81's Avatar
khodson81
Default Starting issues need help
Normally I just use the search feature and it hasn't steered me wrong but I have a problem that I can't seem to find an answer for. First off I own a 1992 mustang that is pretty much stock except for a cold air intake, long tube headers and exhaust. The smog pump has also been removed. Now to the problem. When I first start it in the morning it won't stay running. If i give it gas it keeps going and after a minute or so of doing this it stays running. If I don't give it gas it dies right away. If I drive it somewhere turn it off and then start it back up it stays running as long as I don't let it sit for hours. Any idea what could be causing this problem. From the searches I thought it could be a IAC valve but I replaced that and it didn't help. I also cleaned the MAF sensor. Any help is greatly appreciated as I have no idea what the problem is. Thanks.
Old May 19, 2011 | 01:32 PM
stangmanmike33's Avatar
stangmanmike33
have you checked for vacuum leaks? my car has done this too and i changed some vacuum hoses and it cleared up. a friend of mine had his car doing the same, and it ended up being his intake gaskets. but just a though, dont go and tear it down without some more input from some of these other guys
Old May 19, 2011 | 02:59 PM
88foxjww's Avatar
88foxjww
im having this same problem with my 88. any input would be much appreciated. thanks in advance.
Old May 19, 2011 | 11:25 PM
khodson81's Avatar
khodson81
I have looked. I did find one. The tube that goes into the charcoal canister wasn't connected and I was hoping this was going to fix the problem but it didn't. I will keep checking for other leaks but this problem is driving me nuts.
Old May 20, 2011 | 01:19 PM
Bubba 95SN's Avatar
Bubba 95SN
Check fuel pressure do all the EEC1V tests. The CEL is not always on because there is a fault.
Old May 20, 2011 | 07:37 PM
1987gt40ttop's Avatar
1987gt40ttop
same thing happened with a 88 i picked up. i started checking it over and realized the 02 sensors were gone and the harness which was messing with the fuel curve. i replaced that and rerouted some vacuum lines that were pluged off and it ran fine. i would check over vacuum lines, 02 sensors, and pull a plug see what it looks like that may give you a better indication of whats goin on, rich lean oil water, ect.
Old May 21, 2011 | 12:17 AM
stangmanmike33
that canister your reffering to only vents the gas tank, to keep fumes away from the exhaust in case of a really bad backfire. dont wanna blow it up you know. but yeah what 1987gt40ttop said, check everything really good. the other guy brought up the fuel pressure test too, thats a good idea, you may have a faulty pump, pump relay, or a bad ignition switch.
Old May 22, 2011 | 11:31 PM
khodson81's Avatar
khodson81
I checked more vacuum lines and the one that runs from the intake to that canister was toast. I replaced all of it and it runs amazing now.
Old May 23, 2011 | 02:00 PM
Quickbird144's Avatar
Quickbird144
Thumbs up
Awesome. Nothing like fixing some shady vacuum lines
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
5.0 kevo
Sep 3, 2015 06:24 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
