Help! running to hot
Old Mar 26, 2012 | 10:20 AM
mattdel's Avatar
mattdel
It's not odd at all. The symptoms fit with a cooling system that can't keep up with temperature demands. Larger radiator is an immediate fix, assuming the water pump fin's are still intact.
This is not to say that the coolant ports throughout the engine aren't clogged, because that would produce the same problem you're experiencing.
On a side note, 160 is entirely too low for an EFI system.
Old Mar 26, 2012 | 07:42 PM
Jayson95GT's Avatar
Jayson95GT
What size Tstat would you recommend? like a 180-185?
Old Mar 26, 2012 | 08:33 PM
mattdel's Avatar
mattdel
With a stock tune, you want 195 for optimum balance of fuel mileage/parts weardown/HP.
Though, you have a pretty wild engine. If it was my car, I'd have a 180 in there, just to lean on the side of caution. A 180 thermostat will keep the engine right about 192-195, which is perfect for HiPo EFI.
One thought popped into my head while typing this, and I'm not sure why I didn't pick up on it before. You have a 160 t-stat and electric fan. At that temperature, the fan won't come on until the system is already falling behind, compounding your issue. Do yourself a favor and get rid of the mail order tune.
Old Mar 28, 2012 | 01:14 PM
Dj_Seph's Avatar
Dj_Seph
I'm selling a Fluidyne.;D
Old Mar 28, 2012 | 07:49 PM
Jayson95GT's Avatar
Jayson95GT
May be interested... PM comin your way!
1TUFF302
Nov 5, 2015 04:02 PM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
96stang3.8
Sep 10, 2015 06:42 AM
