need major maf help
Old 05-15-2012, 03:22 PM
g3mustang
g3mustang's Avatar
Default need major maf help
so i have error code 66 and cant fix the problem changed got a brand new maf from abaco still nothin! even traded computers with someone.
I have performed maf sensor dc check list! im stuck on dc7,dc8, dc11 im getting no reading of resistence!
i have check for continutiy of the wires from maf harness to computer plug and i get the little beep!
im so lost i need some direction please
g3mustang is offline
Old 05-15-2012, 08:09 PM
g3mustang
g3mustang's Avatar
I even conected pin c and d from the maf straight to the computer and that changed nothin
Old 05-17-2012, 09:47 AM
g3mustang
g3mustang's Avatar
So I've been having code 66 and has put the car in limp mode!
When this code first popped up i sent my meter to abaco and they said it was bad! So i replaced it with a brand new abaco! Problem still there after new maf installed.
Steps I've done to correct it!
Changed computers
Made sure I'm getting the right voltage at maf with key on engine off
Checked continuity from Maf harness to comPuter plug.
Re did pins c and d on the maf harness straight to the computer
Re did all grounds added more
Replaced iat,vss,and ignition switch
I have no idea where to turn next! Please help the only thing I can think of is I have another bad maf???
What else am I missing
__________________
Old 05-17-2012, 12:51 PM
g3mustang
g3mustang's Avatar
i tested the pin c on maf harness while running got .3v but on pin d blue/orange wire i get zero volts i even get zero volts at the computer?? is my computer bad???
jwog666
12-27-2021 08:09 PM
11-18-2015 01:34 PM
Dan04COBRA
09-30-2015 11:46 AM
treesloth
09-28-2015 07:03 AM
09-10-2015 07:23 PM
Quick Reply: need major maf help
