Positraction
Old 07-03-2012, 10:06 AM
cornelius1988
cornelius1988's Avatar
Default Positraction
I have 1988 5.0 lx only one tire spin no matter if I spin backwards then put it in 1st gear. I was told that because it was sitting for 5 yrs the clutches in the rearend are bad what should I do to get pos traction?
cornelius1988 is offline
Old 07-03-2012, 10:48 AM
van-swink85
van-swink85's Avatar
Rebuild your rear end, it sounds more expensive than it is
van-swink85 is offline
Old 07-03-2012, 02:59 PM
mustangGT86_05
mustangGT86_05's Avatar
It wont go bad from sitting, the clutches wear like anything else so its either due to regular wear, abuse, or someone changed the gear oil and didn't add the friction modifier. You can change the clutches yourself, hardest part will be getting the spring back in place.
mustangGT86_05 is offline
cominus
01-20-2008 11:02 PM
SUPERSTEVE9219
01-18-2008 12:40 PM
SMP
11-21-2005 12:17 AM
Danko
11-18-2005 09:19 PM
StupidTodd
04-29-2005 04:08 PM
Quick Reply: Positraction
