Over fill AOD
Old Apr 6, 2022 | 08:07 AM
Zarmelad123's Avatar
Zarmelad123
Default Over fill AOD
So I just installed a 2800-3200 stall from Boss hog Converters in my stock AOD with 65k miles on it. I was filling it (1qt in converter at install) then 4 qts down the dip stick tube. When running I added 5 more qts, now when running hot it’s reading way over full on the dip stick (10qts total now). I know it’s suppose to take at least 12 qts when dry if completely stock. I called boss converters and talked to the owner. He told me a few things.
1. It should still take around 12 qts maybe more since I added an external cooler.
2. I should have used type F fluid but since I already put it 10 qts of motor craft mecron V just add 2 qts of Lucus stop slip.
3. He said now that I have a 10 inch converter the dip stick will read wrong and to add fluid while hot untill it vents out on the trans after I add the lucus stop slip.
-Thoughts? Is there any issue filling an AOD till it vents?
I also have had an issue where the trans doesn’t down shift fast when coming to a stop sometimes so it stalls the engine a bit till I tap the gas, I’m guessing this is a TV pressure issue? This was an issue before the install and still remains.
Thanks!
Here’s the converter I installed https://bosshogtorqueconverters.com/?product=26403-ford-aod-street-bandit-28-3200-rpm-torque-converter
Wasn’t getting any responses on Reddit so I’m reposting here.
Old Apr 7, 2022 | 01:22 PM
Derf00's Avatar
Derf00
Gentleman's Relish
why would you question what the manufacturer has told you?
If you install according to the Mfg you'll have a warranty. Deviate from that and you're on your own.
8v-of-fury
Jun 17, 2010 10:08 AM
cblevy98
Jul 28, 2008 04:25 PM
sqrlnts
Mar 13, 2008 09:45 PM
turbosha
Jul 16, 2007 12:36 AM
oneslo50
Sep 2, 2006 11:39 PM
