thumper heads...
thumper heads...
Whats the deal with thumper heads, Will it help my car as much as they claim...will they perform as good a aftermarket heads like AFR or edelbrock or trickflow? what kind of gains should I expect?
RE: thumper heads...
If you are interested in ported stock heads, you might want to check these guys out too. http://www.powerheads.com/SB50.html
but it's a proven almost 40 h.p. gain and I bet that you could do a little bit more porting on them and see more results, save up a few hundred more dollars and get your self some good aluminums.
With so many affordable after market heads out there I never understand why people would ever spend good money to port a stock head, unless it is in the rules for a specific class or somthing. Hell you can pick up trick flows used for about $750 and do a $150 vavle job and be way ahead of the even the best ported stockers.
Mikes Stang
04-29-2006 11:47 AM
