rich on the dyno
rich on the dyno
So i took my car to the local dyno and they said i was running really rich. they got it down as best they could in 4 runs but they stil couldnt find the problem so i drove it home still runnin rich. Any suggestions on how to lean it out?
RE: rich on the dyno
Do you have a pressure regulator? Why can't they lean it out? IF they have a tuner there they should be able to set the pulse in the injectors directly and play with the whole fuel system? What timing are you running? Check vacum leaks?
my timing was set too high at first but they lowered it to around 14ish and they said my regulator wasnt adjustable or somethin wasnt adjustable so they couldnt lean it out. how do i check vacuum leaks?
Spray Propane or Ether around the lines and lower intake while the car is idling, if the engine revs up then you found a leak! But dude you gotta get a pressure regulator to figure the pressure, and it will run rich until you get one or get the thing tuned either way you have to spend some cash!
get an adjustable fuel pressure regulator.
ORIGINAL: smokesricers
ORIGINAL: angcobra
If you are using a chip, have them change the fuel table.
If no chip, lower the fuel pressure.
Galactic
04-29-2019 02:56 PM
