Floor Rotting?
Floor Rotting?
Im looking at floorpans because I know I need these but there might be more....it says on 50resto that the floor pan goes to jsut before the front of the rear seat, but there is only a whole the size of your fist in there, where as behind this where the rear wheel well bends down to the the floor of tha interior, along that bend its all rotten out. Im havin trouble explaining this but what would I need to buy to get the whole rotten out that is by the wheel well? All new wheel wells or what, Id get pics but its in storage right now so it doesnt rust anymore.
RE: Floor Rotting?
The floor pan comes in one piece that covers that area. Depending on the size and location of the hole I would suggest cutting out what you need from a local junk yard. If you have an electric die grinder and a saw saw and the junk yard will let you it will be cheaper. I cut out a spare tire well in about 30 minutes and saved about 120 bucks. Sometimes you can find junkyards that will do it for you with a torch. The first thing you should do is take good pictures and measurements. Know what your askinf for and start calling.
ccdguy
09-19-2015 05:20 PM
