wheel bearing replacement
RE: wheel bearing replacement
yes you would, you have to pouned them out from opposite sides at least from the way ive seen it, but if your going to be back there you might as well gear the car as well
If its only the outer wheel bearing you will just have to pull the axles and use sorta like a slide hammer to get them out...Then you can easily drive them back in...With the correct tool..but a big socket that fits on the outer edges of the wheel bearing will work just fine also..
