331 or 351
Old 09-22-2007, 07:24 PM
mostdef
mostdef's Avatar
Default 331 or 351
hey whats up...i have an 87 gt ttop with a junkyard engine about to give out...i currently have an f cam, ez's with 190/160 valves an rpmII upper and lower a 70mm throttle body and spacer, stock injectors and maf, 373gears a king cobra clutch, w/ a 5speed tranny anad 195lph fuel pump...i now want to build an engine that i can drop in and am debating between a 331 rottating assembly from dss or buy everything seperate w/ brodix5.0r heads or a 351..what should i do...what would u guys do...please any comments will help thanks
mostdef is offline
Old 09-22-2007, 10:40 PM
92GreyGT
92GreyGT's Avatar
Default RE: 331 or 351
I am all about using what you have and not having to buy everything again. Sometimes that doesn't work but I do try to do that. If you change to the 351 then you are going to need another oil pan, distributor, lower intake, headers, and a engine. I don't know what your performance plans are but if it isn't to much the 302 based stroker will do fine and you can use the pieces that you already have.
92GreyGT is offline
Old 09-22-2007, 10:49 PM
r.barn
r.barn's Avatar
Sell the cam and EZ heads
keep the RPM-II intake and TB
get new MAF and injectors
fuel pump is fine.
Run about 10.5-11 compression
1 3/4 LT's
Buy 347 long block with Canfield heads and 6500rpm custom cam (available options)
from www.fordstrokers.com for about $4k.
That will give you a 450-500hp (flywheel) engine. make somewhere around 350-400rwhp N/A.
r.barn is offline
Old 09-24-2007, 02:24 AM
mostdef
mostdef's Avatar
thanks for all the help...imma look into all that....most likely sticking wit the 302-347 area
mostdef is offline
Old 09-24-2007, 02:45 AM
nmerrill
nmerrill's Avatar
If i could do it again(probably will next year) I would start off with a 351, much stronger block, and are readily available. But to each his own
nmerrill is offline
Old 09-24-2007, 02:51 AM
w8less
w8less's Avatar
neither 347
w8less is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Mustangs of Illinois
08-22-2015 10:00 PM
MonsterBilly
08-12-2015 12:01 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 331 or 351
