Mustangs do not like ditches!!!
#51
RE: Mustangs do not like ditches!!!
Got it pretty straight. For some reason when the front tires are off the air it seems like the front right wheel has a little more of a positive camber than the drivers side... Looks like the lowest point of the tire is about an inch in from the highest point. the drivers side is about 1/4th of an inch in. I set the camber plate as much as I could to make it as even as possible, but the right side is still a little more positive.
The shock tower on the right side is still in about 4mm the front & behind it seems to be in perfect alignment. From what i'm gathering you have about a 5mm limit before it starts to mess with the tires or handling. Guess i'll see how it handles at higher speeds. Then work on sanding & getting it ready to paint. Can't find the passenger side fender extension (scoop in front of the tire) So may have to paint everything w/o it then paint that later.
#53
Definitely doesn't feel as stable at higher speeds. That may be due to more positive camber on the right side than left. Will have to get an alignment pretty soon & hopefully it will fix it.
I'm not entirely sure if it will get painted tomorrow or not. We'll see how much sanding gets done. I should be able to scuff up the paint & fix a few dings pretty quickly, guess we'll see. I've already fixed a few tears in the ground effects, just needs sanded down. Hopefully I can pull this all off tomorrow. If it doesn't get finished before wednesday I'll have to wait till next saturday before the booth is open again Or I could attempt it in my garage. I'd rather not though. Worried about dust in it. (dirt floor)
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
