can you sandblast rims? help please
im picking up cobra rs that were sprayed black. they need to be repainted. can i sand blast them. and would it be possible to do it with the tires on the rim. if not what are other good ways to clean and paint rims wire wheel them?
RE: can you sandblast rims? help please
If it were me I'd pull the tire from the rim for 2 reasons.
(1) makes getting all the old black paint off easier and has a place to hide what old paint you don't get off.
(2) When you repaint the rims you you can get completely around the lip on the rim.
Again if it were me... I'd go with either Aircraft paint stripper, or Permatex spray on gasket remover: Both will remove paint and ever Powder Coating.
Case in Point,
I used Aircraft paint stripper to remove the paint from my Cobra mini spare before I polished it.
Sprayit one .. let it sit... wash it off!
Someone else used Permatex Gasket Remover to remove there powder coating.
And here's the link to the thread where he used the Permatex Gasket Remover.
http://forums.stangnet.com/showthrea...gasket+remover
