GT40 Heads Question
Old Dec 10, 2008 | 02:40 PM
TotalEclipseTinting's Avatar
TotalEclipseTinting
Default GT40 Heads Question
I have a set of aluminum GT40 heads with 1.99 intake valves and an X cam. Will my valves clear the pistons on my stock 89 engine with 1.7 roller rockers?
Old Dec 10, 2008 | 03:04 PM
Tberg725's Avatar
Tberg725
You mean 1.94? you're gonna run into ptv problems on a stock bottom end.
Old Dec 10, 2008 | 03:09 PM
TotalEclipseTinting
Sorry 1.94. So it will not clear?
Old Dec 10, 2008 | 03:35 PM
Timspony's Avatar
Timspony
SVT Section Moderator
No to the question ^^^! ...you would have to notch your pistons or replace...1.6's will work...
Old Dec 10, 2008 | 03:36 PM
TotalEclipseTinting
Thanks
Old Dec 10, 2008 | 04:45 PM
jtmustang's Avatar
jtmustang
not necessaryily as i have seen bigger cams (tfs stage 2) clear just fine and for the hundredth time it does not have to do with total lift but more the total timing events..
Old Dec 10, 2008 | 05:21 PM
Tberg725's Avatar
Tberg725
But.....an X303 on a 1.7RR is going to be bigger than a tfs2.....the 1.7 rocker arm is going to add .33 to the X cam making .575 lift and we all know it all has more to do with duration but thats just not going to clear............
Old Dec 11, 2008 | 12:28 AM
jtmustang's Avatar
jtmustang
u will never know without checking bvut the 1.7's might not make it work...
Vrooom
Feb 21, 2016 05:25 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
