Vibration problem
Old Dec 14, 2008 | 10:44 PM
NastyNate65's Avatar
NastyNate65
The vibration started right after i installed the new tranny, clutch, and flywheel. I know my tires are balanced, and besides, I can feel the vibration in the shifter, so i dont think its the tires. But I will try rotating the driveshaft and see if that does any good.
Old Dec 15, 2008 | 05:16 PM
Jerome99's Avatar
Jerome99
I have the same problem, i have a c4 tranny, I cant figure it out.
Old Dec 15, 2008 | 06:27 PM
mustangsneverdie's Avatar
mustangsneverdie
check to see if the driveshaft is bent I believe that's what's wrong with mine
Old Dec 16, 2008 | 09:05 PM
Jfsram's Avatar
Jfsram
Marking the driveshaft is definately overrated. Just like marking a wheel stud and bolt hole to return a wheel back to it's original position in relation to a brake rotor.
First confirm it's driveshaft related. Drive 60 or more. Where the vibration is the worst. Now drop it down a gear and maintain the same speed.
If the vibration changes you need to focus on engine speed related vibrations. Clutch, flywheels, pilot bearing etc.
Old Dec 16, 2008 | 09:57 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Originally Posted by mustangsneverdie
wtf does marking the driveshaft do? I've never done it
Nothing! In 20 some years of working on cars, I have never marked one or had a problem. The drive shaft is balanced before it goes in the car, not after. It's just an old wives tale.
Edit, lol portmaster, I just read your response and saw the same thing I said. Guess I should read the whole thread before I respond huh?
mtgldr
Feb 3, 2024 09:00 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
LivingInThePast
Sep 16, 2015 12:20 PM
