Should I get a Mustang? Reliability
The Tweecer R/T is the way to go. It's got a huge support network and you can even download other people's tunes as well to suit your needs. I use it on my 95 Vortech'd mustang.
The thing if you get a 94-95 is that there are no piggypack tuners, since the computers are OBD1. You can get chips and tunes that way, which, IMO, is more effective. As for tuning yourself, you can get an adjustable FPR, adjust the timing, or buy yourself an AEM program so you use your own comp to burn chips
Ive driven my 95 30k and have never had ANY problems, not even the battery dieing
almost half a million miles, that is great. original eninge?There has to be more efficient engine management for OBDI Mustangs, correct me if I am wrong.
Weird thing, some people say that Mustangs are almost undriveable in the snow and others say that they don't have any problems! I personally have no idea who to believe because I have never driven anything RWD in the snow.
My father has been driving his RWD cars daily every winter and he says that a set of Bridgestone Blizzaks is all I need.
I just looked it up and it seems like it is around $400 which is very affordable. So from what I understand it will work on pre-1996 Mustangs and will allow me to adjust my fuel and timing tables to whatever I want? If it does, then that is exactly what I need!
I remember that happening at some auto show I saw on TV, the guy hit a million miles on his SAAB and they gave the guy a brand new car.
Well not quite. At 83,000 the thermostat got stuck and the car overheated. He ended up cracking the block trying to get to a mechanic. The motor does have close to 400,000 though. He bought a new one and boy was it expensive. It is not as bad as you think either. He changed his oil every 2,000 miles with Havoline. It must of worked because he doesn't add oil between changes. He is on his 3rd auto transmission. The first one went 222,000. He had it rebuilt and it lasted till about 430,000 miles. He went to get it re-built again and they told him to get a used one, there was nothing left to re-build. Keep in mine this guy doesn't rag his car.
I hope I get the same luck out of mine. I am adding a Kenne Bell so it probably won't happen. I hate to chop up a triple white mustang but, it is mine and I will do as I please.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
and they are fine in the snow if you know how to drive or have a nice set of snow tires.
