OEM MAF vs 70mm 1993 cobra MAF
Just shot some picture's of the '93 cobra MAF i got off ebay for $60 vs my stocker.
(this '93 cobra maf has been programed for 19lb injectors)
thought some of you guy's would be interested.
enjoy!
took a no-flash picture so you could see just how TINY the exit of the OEM maf is compared to the cobra.
im expecting a decent power gain, as this is the last "bolt on" for my car.
maybe nothing "wow" to gain, but hopefully ill gain 10rwhp.
thanks!
enjoy!
thanks!
btw i wont be installing it today, the OEM maf in these picture's is a extra i had laying around.
after the "blizzard of 08/09" yesterday, this is how my car currently look's
my 8" antenna was covered, it was 11-13" of snow ontop of the car.
just to show the depth of the snow
the 93 combra maf had a slightly different transfer function over a stock maf which can cause some slight running issues. You would be better off with a 94-95 maf which matches the transfer function of the stock fox maf alot closer
im hoping to have no issues, have a dyno day on the 4th, so ill be able to check it out.
to many issue's and ill just put the OEM back in, and sell this one for what i got it for.
thank's for the head's up Adder
we are moving soon into a house, and ill have a 2 car garage, so no more of this crap for my car.
We got hit down in the springs too but now that much snow. That sucks, thank god I moved into a house right before winter or my stanf would be covered too!! Good luck with the MAF!!
I bought the same thing. It will probably surge and run rich. It probably has a F4SX-XXXx-ax Sensor in the housing from a 94 T-bird/Cougar. Simply, remove it and install the one from your 55mm stock MAF and it will run fine. Mine does
jwog666
12-27-2021 08:09 PM
Dan04COBRA
09-30-2015 11:46 AM
