Overheating
Old Apr 29, 2009 | 05:48 PM
calfroper_06's Avatar
calfroper_06
Thumbs down Overheating
The cars got thise little overheating/warm thing going on. When i built the motor i installed a new napa water pump, 180* termostat and switch my sn-95 fan for the taurus fan.
Now if i cruise and take it easy say at 50 mph cruise speed everthings fine, but if i go do a few pulls and but my cruise speed up to 70 or so the temp climbs up to about 200, then if i really get to romping on it it goes to 210*. SO i pull over and let it idle and it cools down. Im figuring i have a few air pockets, and was wondering what the best way to make sure you have all the air out of the system?
Old Apr 29, 2009 | 06:07 PM
cch's Avatar
cch
Run it and get it warm, after it over heats like that turn it off, pop you hood and unplug your thermostat sensor which is on your lower intake. I think it's a 17 mm wrench you'll need but anyhow. Slowly crack open your thermostat plug just a li'l bit, let some air out then after a while keep opening it up a li'l at a time till eventually you have it totally unplugged at which point you should have let a substantial amount of air out.. which also means you can put some more coolant in the engine. Might be able to do this process more then once depending on how much air is in there. Good luck, let us know how you make out!
Old Apr 29, 2009 | 06:21 PM
calfroper_06
thanks cch, i have the auto meter temp gauge so mines 19mm, but ill go do that now
Old Apr 29, 2009 | 06:25 PM
cch's Avatar
cch
No problem, hope it works out for ya!
Old Apr 29, 2009 | 09:23 PM
domindart's Avatar
domindart
get a new radiator.. just kidding
Old Apr 29, 2009 | 09:46 PM
grabbem88's Avatar
grabbem88
20* shouldn't be much of a concern really ..add the texas weather...what about gauge variance between actual thermostat opening temp vs intake temp?
you might have air in the system...but what got me is what you said about stopping and it cooled down vs driving or getting on it and it climbs.
too much timing under hard loads?
under drives?<i only use the crank..toss the rest in the garbage.
inadiquate cfm on the electric fan?<i ran two 1600's
just some idea's and personal experiences
Old Apr 29, 2009 | 09:59 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
running lean will cause it to get hot real fast
Old Apr 29, 2009 | 10:02 PM
grabbem88's Avatar
grabbem88
i thought i added that?? oh well oversite on my part,but yes lean condition will heat the cylinders and block
Old Apr 29, 2009 | 10:05 PM
84conversion50's Avatar
84conversion50
since when is 200 and 210 hot?
Old Apr 29, 2009 | 10:13 PM
grabbem88's Avatar
grabbem88
it's not...if want's things to check i gave him something to do..that way maybe his conscious would be at ease.
but if his temp climbs at a steady state as engine load increases i'd be concerned,although he shut it down before it got "hotter" who say's it wouldn't..
regardless if it is 200* 220* a properly working cooling system with a 180* should balance out at a given point..not increase progressively
