Blocks and Heads
Old 08-31-2009, 09:13 PM
Mr.S
Mr.S's Avatar
Originally Posted by mjr46
read my question again, that's not what I asked....more clearly stated, how do you know it has 400hp??? what has been done to the motor?? any et on it/track times/ dyno sheets???
I'm sorry I didn't get back to your post. Well I don't know about the track time/dyno sheets. Because I didn't get any when I bought the car. I need the replace the trans because the synchro's to 1-2 are gone and 2-3 are just about to be gone. From What I understand about the engine, it is a built engine with not alot of miles on the car already. So the engine is pretty much new. I will not know about the times right now because of the trans, but my dad say it can be a 10 second car. Which I don't know.
Sorry for the lateish(not a word) reply. I was busy trying to get my crappy plymouth neon back home today. It died while I was about 10 minutes from home.
Mr.S is offline
Old 08-31-2009, 09:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
take a picture of the engine
mjr46 is offline
Old 09-01-2009, 08:22 PM
Mr.S
Mr.S's Avatar
I couldn't get a picture yet. But here are the specs.
302 bored .060 over
Crankshaft ground .010 and polished
Forged TRW pistons (unsure of compression ratio)
Comp Cams Extreme Energy .541 intake .544 exhaust
Summit Gear Drive
Stock cast heads new valve springs and valve job adjustable valve train
Edlebrock performer intake
Holley 800 double pumper
Summit Billet distributer
MSD ignition and Hi Energy Coil
Dynomax headers
8.8 Rear with 4.56 gears
Eaton Traction Loc
31 spline axles with C-Clip eliminators
Mr.S is offline
Old 09-01-2009, 09:13 PM
AdderMk2
Banned
AdderMk2's Avatar
bud... you aint NOWHERE near 400hp
AdderMk2 is offline
Old 09-01-2009, 09:17 PM
mjr46
mjr46's Avatar
302 bored .060 over
Summit Gear Drive
Dynomax headers
Eaton Traction Loc
HMMMM? Don't take this the wrong way , I mean no disrespect but with stock heads, a performer intake and a 800 cfm carb, the combo is poorly matched and that combo will in no way produce 400 rwhp, with edelbrock rpm heads, rpm intake and ford f-cam .512/.512 lift, A 650 DP CARB and 4 .11 gears My friend laid down 288 rwhp..to give you an idea
mjr46 is offline
Old 09-01-2009, 11:18 PM
AdderMk2
Banned
AdderMk2's Avatar
If that car has 400hp, i must be around 650
AdderMk2 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Drastang
09-30-2015 03:48 AM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Blocks and Heads
