Master cylinder help
start at rr then lr nextis rf last is lf. r=right r=rear l=left f=front Try bleeding one more time.Check reservoir cap for plugged vent holes.Check for bad linesandcaliper seals. Water contamination in system. Bleed all fluid out of hcu and lines.
tomorrow on my lunch break im gonna bleed my brakes again and im gonna bleed out as much fluid as i can cause driving it today it kinda does feel like an air bubble.
also i doubt it can be a hole in the line because i pumped the hell out of it in the middle of the street and there wasnt a drop of fluid on the ground
