underhood gauge?
i dont get why some of you are running what your running ?? in that pic.... is just the needle removed to allow the female adapter over the schrader valve ?? im confused
if you remove the inside of the schrader valve you have a 1/16 female port to tie into.
so you just need a 1/16 male npt X 1/8 female npt adapter and nothing else unless you wanted to 90* it up
out of that you can run a 1/8 X 1/8 X 1/8 brass tee. and use it as a 90 AND an extra port. pic sux cuz it was dark and real cam is dead. but you'll see what i mean
since i am running a wet kit i needed the -4an fitting to come off of it. so thats why i ran what i suggested.
ya i kno my fittings are multi colored but i bought the cheaper ones so i got what ever color they came in LOL
and i mounted the zex box under the MAF bracket so thats where the 90* goes
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
