crank issues? bottom end ka-put?
Just drive it lol, I still beat the hell out of mine....when its not in the garage.... If it breaks then it breaks. Winter is comming up soon so you have that time to put another short block in so you can at least drive it lol. I have noticed mine still leaks out of the front timing cover. I think that my crank has just gotten weak because when I checked it on the snout of the crank with a dial indicator it flexed a good amount just from me turning it with a breaker bar.
try to get a personal best at the track before it closes.
I can rebuild this motor for super cheap, it will probably make even more power on motor because it would be fresh, and not like it is now, 30psi low on one cylinder....
but with a 150 shot, the block is not going to last to long...... but putting in a 351 is not cheap, even a budget minded 351.
I have to add everything up before I decide :/
no ones sells **** around here. only dummies try to race up here in the mountains
i race up to the mountains cause i love it up there. trail ridge road...LOVE IT!
been down to royal gorge? really neat chit. also i love the set up for your outlet mall in silverthorn...place is freakin sweet.
anyways, if you need some assistance on a build just let me know, 302 or 351 i'll lend my brain to you.
lol, anything for a fellow racer.
but at this elevation its horrible for racing.
thanks for the offer, ill probably take you up on helping me out a bit.
at the moment, with my limiter funds, I think my best bet is just to rebuild this motor
shot a video......
hooked the oil pressure gauge back up. hasn't worked in two months, but back then, when the motor was cold, it would show almost 50psi.
now......... about 10-15psi when the motor is cold.......
I think its time for a rebuild
http://www.youtube.com/watch?v=OEAL0v4mdw0
just this unexpected **** drives me nuts.
makes me want to sell this hunk-o-junk and buy a motorcycle again.
