crank issues? bottom end ka-put?
Old Sep 25, 2010 | 05:08 PM
  #41
68CSTANG's Avatar
68CSTANG
I think an 8.2" motor could fulfill ANY power level you want to make. So that is where my vote is. Keep the heavy, slow-revving 351W's in pickup trucks (installs flame suit)
But seriously, that sucks about the oil pressure. Rebuild it cheap and enjoy the rest of the season.
Old Sep 25, 2010 | 05:26 PM
  #42
302army187's Avatar
302army187
you mean a dart block?
kinda rich for my blood.
Old Sep 25, 2010 | 05:56 PM
  #43
68CSTANG's Avatar
68CSTANG
Well any aftermarket block will be fine. Or even a 60's 289 block would hold close to what a windsor would IMO. It's just money man
Old Sep 25, 2010 | 08:14 PM
  #44
DJ19895.0's Avatar
DJ19895.0
I just installed a new oil pressure sending unit the day I got the gauge working again. and yes the wiring is right, no other way to do it wrong.
also the dowel pin's are in the flywheel and properly installed
Not saying that you installed / wired the gauge wrong, but a bad connection anywhere in the circuit can make a huge difference in readings. Good luck with your car man, I hate putting my heart, soul, and cash into mine, and then having it not work correctly, haha.
Also far fetched, but your flywheel has a 50 OZ. imbalance, and MUST be aligned correctly. Did you install it in exactly the same position as it came off the crank in?
Not trying to make you sound like an idiot, just trying to help =S
Old Sep 25, 2010 | 08:23 PM
  #45
68CSTANG's Avatar
68CSTANG
His flywheel should only go one way typically. But if it doesn't then you are right. It would be like taking weight out of the wrong angle of the counterweight.
Old Sep 25, 2010 | 08:27 PM
  #46
302army187's Avatar
302army187
yea I understand.
no, the flywheel can only be installed one way, which keeps it in balance.
anyway, this doesn't matter..... look at my next post. I think Its now clear what the problem is
Old Sep 25, 2010 | 08:28 PM
  #47
302army187's Avatar
302army187
**** MY LIFE
oil strait from the filter into a clean bag
Old Sep 25, 2010 | 10:34 PM
  #48
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
ooooooo shiiiiinnnyyy....oo wait thats a bad thing....
Sucks man! At least your not wondering much anymore though and know its time for another build!
Old Sep 25, 2010 | 11:18 PM
  #49
302army187's Avatar
302army187
yea, at least its pretty much undeniable proof.
going to call the local performance shop on money and get a quote for them to go through the motor with me tearing it down and giving them all the parts, to measure and fix any issues with the crank/rods, maybe new pistons, and to put it back together properly for me.
Old Sep 27, 2010 | 08:50 AM
  #50
ProTrickVic's Avatar
ProTrickVic
yikes. sad to see mah man.
with that much flake i wonder if there is even a bearing left....
