crank issues? bottom end ka-put?
Old Sep 23, 2010 | 10:02 PM
  #31
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
id honestly just call Jim @fordstrokers and either get a 331 or 347. i know's money's tight, but eventually youre gonna want a bigger motor so just get it done now and be happy
hey look on the bright side; at least youve still been driving yours...
the last time mine moved was almost 2 years ago and that was under human power...
i think the last time it ran on its own power was almost 3 years ago...
Old Sep 23, 2010 | 10:08 PM
  #32
302army187's Avatar
302army187
nah. I got a hungery for speed that cant be fixed with 450-500hp that a stock block can take. I want around 800.
so a 351 is the easiest, cheapest way of doing that. Just at this moment...... I cant afford ****, and I can't bring myself to let the car sit for a entire year until I can build a 351.
i would rather get the 302 rebuild, and have it back up and running pretty quick, then take forever to have a 351 come together.
damn, 3 years? I couldn't do it. I would have sold it
Old Sep 23, 2010 | 10:17 PM
  #33
sn95_331_GT_ yellow
there are days i got to my moms house (i have no garage) and see it there and almost start crying, but when i get home and see the huge pile of goodies in my work area, my mood goes up a lot.
im about a month out on getting my heads, then itll be time for Jim's 331 kit, then a whole bunch of other crap, but i just want to crank it up and hear it rumble...
  #34
Shelty's Avatar
Shelty
if its easy enough for ya, just rebuild the stock engine, or look for an exploder, tho idk if those had the forged pistons cuz i know you like the spray.
tho the heads you have would work with a 351 right? I mean they would be on the smaller side, but you can make that back up with the spray....
Old Sep 23, 2010 | 10:33 PM
  #35
302army187's Avatar
302army187
haha, yea, there have been times when I'm working on it that I have to avoid my garage, or ill get pissed and want to part it out. so its probably better its at your moms place.
i priced out the 351 swap. not going to be able to afford it for a long time.
So 302 rebuild it is.
just have to see if I can afford high compression pistons with big enough valve reliefs for this cam.
even a mild 351 with my heads and cam should ATLEAST pic up 30rwhp by my math. so it would still be a pretty good swap considering the upgrade in block strength and growing room......... but I cant swing the funds right now
Old Sep 24, 2010 | 06:31 AM
  #36
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
A basic 351 swap would cost about 1k from what I have looked into. I have thought about it too. The only thing I am lacking for a swap is a rebuild kit, accessory brackets, and the oil pan kit. That and the motor itself is in Indiana and I am in Texas lol
Good luck with the rebuild!
Old Sep 24, 2010 | 06:58 AM
  #37
Bubba 95SN's Avatar
Bubba 95SN
Had the engine out and did not check bearings...mistake. Next time.
Old Sep 24, 2010 | 08:38 AM
  #38
302army187's Avatar
302army187
well from what I looked at its $1550 just to put the motor in the car,(minimum, if you buy decent parts, its $3k to put the motor in) not including getting the 351 and having it rebuilt, which is probably atleast 500-900.
I just cant swing the $2500 minimum right now. It would probably end up being closer to 4000-5000 total
yep, I know. I was to intimidated to do it myself.
could have saved me from all this grief and work. but live and learn I guess.
Old Sep 25, 2010 | 10:46 AM
  #39
DJ19895.0's Avatar
DJ19895.0
Before u take the engine back out, check to make sure that the oil pressure gauge is correct. Hook up a mechanical one to make sure. If the oil pressure is still low, rebuild it.
Vibration issue: I JUST had the SAME problem after my rebuild. I forgot to install the three pressure plate dowel pins that help to align the pressure plate. I figured there was 6 bolts that align it anyway. WRONG. Bad vibration after 3k! Apparently even 1mm off center makes a massive difference. After 12 hours to pull the trans again and install the pins, it rev's butter smooth through all rpms. It is a long shot that you also did the same thing, but it could save you from a rebuild, haha
Old Sep 25, 2010 | 01:21 PM
  #40
302army187's Avatar
302army187
I just installed a new oil pressure sending unit the day I got the gauge working again. and yes the wiring is right, no other way to do it wrong.
also the dowel pin's are in the flywheel and properly installed
