5.0 HO firing order
Old 09-25-2010, 07:08 PM
pdiddy5.0
pdiddy5.0's Avatar
Default 5.0 HO firing order
Need some help with the firing order
I accidentally pulled the distributer out without marking the position of the rotor.
Now the car is barely running
What is my best solution to getting the firing order corrected
Any help would be appreciated
Thanks
pdiddy5.0 is offline
Old 09-25-2010, 08:22 PM
Bubba 95SN
Bubba 95SN's Avatar
1-3-7-2-6-5-4-8 Counterclockwise.
Bubba 95SN is offline
Old 09-26-2010, 10:27 PM
nitrous_bob
nitrous_bob's Avatar
pull the plugs and turn the motor over by hand so you know your not 180'd
put your finger on the #1 hole...when it goes "phsst" then stop the dial on "0" thats tdc on compression
mark the inside of the dizzy where the #1 plug terminal is. when you stab it.... make sure as it rotates down it is still pointing at that mark.
nitrous_bob is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
Meystang
09-25-2015 04:05 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: 5.0 HO firing order
