Engine Build Question
Old Mar 26, 2011 | 02:34 PM
VRFlip's Avatar
VRFlip
Thanks for the heads up guys, looks like I need to order a Flexplate.
Old Mar 26, 2011 | 03:19 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
Originally Posted by 67mustang302
It still needs balancing with everything on it. It's to balance out the vibration caused in the crankshaft(which functions like a giant tuning fork). You won't know what the vibration is without sticking everything on it and spinning it.
I see your point but, I don't see why. I understand that the different weight of the piston and rod could affect it but, if I tell them how much they weigh, why couldn't they balance the crank without having the piston and rods.
Old Mar 27, 2011 | 02:36 AM
67mustang302's Avatar
67mustang302
If they knew exactly the weight they could, yes. But you can't JUST weigh it. The parts are weighed, then the big end and small end of the rod are each weighed and you do some math to account for that, and assemble a bob-weight. That's all that's on it when they're balanced anyway, is just a bob-weight bolted to the journals.
They still need the balancer and flywheel on it though, I thought you were saying why would they need those. Balancing requires crank, bob-weights, balancer and flywheel/flexplate.
Old Mar 27, 2011 | 03:08 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I was kinda. Then thought better. I would think if he went to a TRW .20 over piston, he may pull off getting them back to the weight of the standard piston. At least the chances would be better than a .30 or .40 over. Running a TRW piston is kinda really useless though since they are so heavy but, like mentioned earlier if it was blown, it wouldn't matter. It would make more than enough power.
Anyways, I just can't really see putting a whole lot of cash into a stock 302 block. Or even a 351 block. After watching a guy around here run 9s with a 70 model windor headed engine and seeing how much fun he had with it, I don't think I would want anything other than that for racing. After he sold that motor for 2 grand, and built an aluminum headed motor that was way quicker, people started talking so much more **** to him. He said the other night, he was going to sell that motor and go back to another piece of shiz motor just because of the fun factor. It really is kinda amazing he got it to run that fast and I could probably never get one to run like that until building many of them but, after enough trial and errors, I believe I could get close.
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Calizic
Aug 28, 2015 01:46 PM
classic69FB
Aug 12, 2015 11:58 PM
StangMuscle
Aug 12, 2015 07:27 AM
HIS S-197
Aug 10, 2015 05:47 PM
