balanceing crank
Old Jul 14, 2011 | 08:32 PM
93 stallion's Avatar
93 stallion
The engine was recently rebuild before I bought it. To make a long story short, it didn't have good compression on four Pistons so I took it apart. The top rings of those Pistons were broken. So the machine shop was able to just bored it to .040 when it was .030 over. So the formal owner had told me and I see the crank that it is balance. I'm going to buy the same Pistons but .040 over and the differents is only 5grams. What should I do?
Old Jul 14, 2011 | 09:09 PM
tinman's Avatar
tinman
Simply get the balance checked with the new pistons.....
Old Jul 14, 2011 | 09:55 PM
Venomantidote95's Avatar
Venomantidote95
If you dont have the answer by now your blind!
Old Jul 19, 2011 | 01:27 AM
93 stallion
Ok so I ask the machine shop what exactly did he need to balance my crank, he said that the only thing he needs is the crank and rods. So I ask what about the Pistons and said no cause they weight the same. I just want to know if his right or should I find some body else.
Old Jul 19, 2011 | 09:43 PM
68CSTANG's Avatar
68CSTANG
If the pistons weigh the same, then what is being balanced? Did you change rods? Is it a new crank?
Old Jul 19, 2011 | 10:14 PM
93 stallion
I'm changing Pistons size, from .030 to .040 and the same brand. I think his wrong. I'm going to call another shop.
svfetter
Oct 5, 2015 11:39 AM
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Wombatnation
Sep 13, 2015 09:16 PM
Sep 8, 2015 11:50 AM
