Higher output alternator
Old May 21, 2012 | 01:07 AM
StevoX1's Avatar
StevoX1
Default Higher output alternator
In my 93 5.0, i'm running a sound system, alarm and an electric fan. Would it be wise to put a higher output alternator on it? Ive noticed sometimes at idle the meter bounces slighty and when I had it at my mechanics for a brake job he was telling me how the stock alternators, mine is replaced but has the same output, were not really designed to run an electric fan, however my stang needed it... driving down to the beach on a hot weekend in So Cal with traffic would cause it to run a little hot.
Old May 21, 2012 | 01:20 AM
mustangGT86_05's Avatar
mustangGT86_05
The fox alt's were really weak, like 45 amps max. The sn95's introduced a 3g alt with 120 amps, it is possible to swap them onto the fox's too. Look it up, in fact if you view tech articles there's a write up. You just need to solder a couple wires, trim the alt bracket slightly and then it bolts right in. The pulley is bigger though, so you may need a slightly bigger belt. Its a worth while swap
Old May 21, 2012 | 05:38 PM
StevoX1's Avatar
StevoX1
would it be wise to go to a 130? or just 95?
Old May 21, 2012 | 07:16 PM
mustangGT86_05
If you do the 3g swap you wont have to worry about supporting your added electronics. I did it on my 86 and I have 0 problems with it.
Old May 21, 2012 | 07:56 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I bought a small case 3g alternator. It was high. Like 155 but, it did come with directions and all the wiring and fuse links needed.
Old May 22, 2012 | 01:07 AM
StevoX1's Avatar
StevoX1
where you think is the best place to pick one up at? online?
Old May 22, 2012 | 02:34 PM
mustangGT86_05
I bought mine through a parts store, the wire, plugs and circuit breaker I got on ebay. All seems to work so far
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
breaking
Oct 2, 2015 01:27 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
cbird1177711
Sep 3, 2015 08:43 PM
