This a good budget engine set up?
Old Aug 29, 2012 | 07:51 AM
Tony71502's Avatar
Tony71502
Injectors will be too small for a blower.
Old Aug 29, 2012 | 09:24 AM
89LX Coupe's Avatar
89LX Coupe
Originally Posted by Gt 5 point 0
Hey guys, Ive been looking around for a good budget set up for my 5.0's engine.This is what ive been thinking about.
Gt40p heads ( know some1 at junk yard , can get good cond. one for like nothing, so if u have better heads that i can find in a junk yard tell me! haha)
B303 cams ( love the sound of those bad boys)
BBK 75mm Throttle body
Cold air intake, Already have.
BBK Chrome Equal Length Shorty Headers
Im not to sure on which Intake to Purchase. Would a Cobra one work? or would I have to go bigger like edelbrock?
That should give me a good amount of power. How much you think?
tell me whatcha think and what i should change. Remember that its a budget build. Thanks guys!
It's not too bad of a set up for a budget build. If you could try to swing the cash for a used set of aluminum heads you'd be much happier! but if all you can afford is the iron gt40 heads then try to find the regular ones and not the P heads so you can use your headers and not burn plug wires left and right.
Get 1.7 rockers for it and that should help the hit of the cam out too just get upgraded valve springs for the heads. Use the stock valve covers like posted before and take the baffles out of them (both covers). If you could find a 94-95 cobra intake that would be best and it'll go with your parts well too. I don't see where the 75mm throttle body would be too big but 70mm would work fine too just gasket match the opening on the intake and get you a bigger maf as well.
Get a o/r mid pipe or one with hi flow cats have 3.73's to 4.10's installed if it hasn't already been done I'd recommend an adjustable fuel pressure regulator when you have everything apart along with a fuel pressure gauge. The stock injectors are fine for now but when you go to put a supercharger on they will be too small and at that point just upgrade them.
Old Aug 29, 2012 | 09:27 AM
89LX Coupe's Avatar
89LX Coupe
That should give you a decent jump in power over stock depending on how well it's dialed in and if you go and get it tuned I could see you making 250-270ish to the wheels on a dynojet.
Old Aug 29, 2012 | 09:58 PM
Venomantidote95's Avatar
Venomantidote95
Most supercharger kits will give you an injector option, stay around 10lbs and you will be fine!
Before jumping to boost or power adding do your basic bolt-on upgrades first! If you seriously plan on boost choose your upgrades accordingly!
djbigskrilla
Sep 20, 2022 01:04 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Stilz
Aug 19, 2015 06:17 AM
ding56
Aug 14, 2015 02:40 AM
Jacob4589
Aug 8, 2015 11:00 AM
